Engine Section
4
Engine Section
Engine Section
I have huge engine assembly (the attached picture is just a sample ).
I need to create a step file which will be used for an Unigraphics project.
I do not need all the engine assembly; let's say, just the nearby components of the blue right pipe.
It may look like a section cut vertical at 20mm from the right blue pipe.
I assume that there are a lot of surfacing and body entities.
How would you create this job?
MZ7DYJ
RE: Engine Section
I mean, how would you cut the surfacing and bodies in order to have a step file as small as possible?............
MZ7DYJ
RE: Engine Section
only by deleting the surfaces and bodies which are not required.
RE: Engine Section
First try to reduce your model by using intersection trap rectangle in graphic area, selecting what you don't need. Then deactivate (terminal node) what was selected. In CATIA should remain in grphic area what you need and very little stuff in addition, I suppose it will work. I never tried to use the split feature from assembly workbench (none of the companies for which I worked is using) but you can take a look.
Deleting and cutting CATIA stuff is time consuming.
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
RE: Engine Section
I agree with ferdo. You can deactivate the parts/products in the CATIA model tree not needed to produce the section before exporting the .stp file. However you might need to adjust your settings for exporting a .stp file from a product. The most compact result will be to export the product as a single multi-body .stp file with no links. The .stp file will have a single isolated manifold solid for each part in the product, but there will be no surfaces/lines/curves/points/etc in the exported .stp file.
Once you have the .stp file you can import it back into CATIA or UG to create a section cut of the solids. If you wish to make a section cut in UG that includes surfaces, you will need to export the CATIA product as an .igs format. But the .igs format will be composed of just surfaces/lines/curves, so the resulting section cut in UG will not recognize which areas are part of a body.
If you have the correct license, you can create a section of the CATIA product and then save that section cut as a .stp or .igs format.
RE: Engine Section
Thank you all!
MZ7DYJ
