How to simplify Modeling process ?
Hi Everyone,
I need your help/suggestion on my issue.
I work with modeling of electrical components (viz...Circular connectors, Back shells, etc...)in UGNX 8.5.
My job is to model each circular connector separately for different shell sizes in same series. I want to make my work simple and to be completed in less time.
For Example: (Please see the attachment)
I have modeled a circular connector with shell size 9 with respective dimensions as shown in the image,
I need to create separate UG parts for each shell size. Currently I'm doing in the below method.
At First I'm creating UG part with one shell size, later I'm making save as from previous part and resizing the dimension according to the specification. For creating all UG parts for separate shell size it was consuming more time.
Now, I'm looking for the solution to make this whole process simplified. I need your help/suggestion for the same. Please suggest me any method ?
I have one idea but, I don't know how far it can be achievable? i.e I want to make one UG part/template feeding all the information regarding dimensions of all shell sizes. So that whenever I want to create same part with different shell size, then with just one click the UG model can be updated with respective dimension of that shell size.
Is it possible in UGNX? If so, How ? or Any easy/simple method?
Please advice.
Thanks in Advance
Thanks & Regards,
Sam
RE: How to simplify Modeling process ?
Define the key driving dimensions of a design, make expressions for these dimensions that the user can easily change. Change the expression values to different (but valid) values. Make note of what features in your model fail or update in incorrect or unexpected ways; adjust your model strategy so that the model updates correctly. Test for other values; when it works as expected you can use it as a template file or use it to create a part family.
www.nxjournaling.com
Cowski,
Thanks for your reply,
Can you tell me more about part families and how to use them? or Can you share me, If you have any tutorial regarding the same. (Please help me with the procedure of making this template). If I gave you one modeled connector(UG part) with one shell size and give you another shell size information. Can you give me back that ug part, by feeding part family stuff. So, by taking your part as reference I will create similar template for other series.
Once again thanks for your time ans support.
Thanks & Regards,
Sam
maybe check www.youtube.com for a video on "part families"
I am at work right now and cannot access "youtube" so I don't know what's there
Sure
Thank you..
