Diesel Generator Exhaust Usage
Dear Members,
My company has assigned me the task of increasing Diesel generator efficiency and optimizing its fuel usage and thereby reducing the cost of KW produced. Therefore I need ideas in how to improve generator efficiency and how can we use the exhaust released from these gensets. We are currently planning on using this exhaust for vapour absorption chilling or pre heating the water for boilers. I need some more ideas in how can we utilize this exhaust.
We have 5 CAT Generators of 1275 kva each and each gives out exhaust of 236.8 m3/min at 448 Centigrate.
RE: Diesel Generator Exhaust Usage
Here is a link to the Caterpillar A&I Guide for Cooling Systems, there is a section on heat recovery for general guidelines,
http://www.gregorypoole.com/SiteCollectionDocument...
I am most familiar with three companies that provided heat recovery silencers, they are,
Maxim
Cain
Vaporphase
Depending where you are in the world there may be others as well.
Mike L.
How regularly do you run your diesels? Same in winter as in summer?
What do you need energy for? Air conditioning? Heating? Lights? AC only a few months of the year?
Can you use low grade (medium temperature) hot air? (Diesel exhaust itself is toxic, but can heat a modest amount of air a little bit above inlet temperatures, can heat water modestly but only when the diesel is running, but is very, very poor at trying to heat a large industrial process like a boiler or chemical tank.
The diesel exhaust is at modest pressure but is filled with toxic fumes and exhaust particles and (possibly) corrosive gasses and particulates. But you can use the pressurized gas to do some things: Most obviously, as a supercharger or turbocharger to use the pressurized gas to run a shaft. That could be expensive of it fouls up the engine controls through.
Waste heat recovery (diesel exhaust to air) for winter use is the simplest.
