Hydrology report
Hydrology report
Guys:
Can you please educate me on the Hydrology reports. We received a hydrology report for a wind project. HydroCAD was used to model a 25 year flood event. Culvert calculations were provided in the report.
If I want to check the report can you tell me what to look for specifically/ in general in a hydrology report?
I appreciate your time
NT
NT
RE: Hydrology report
A complete hydrology report should have the following information:
Project Summary.
Discussion of the relevant design criteria, and how the project will meet that criteria.
Narrative and graphical depiction of the existing conditions of the site.
Narrative and graphical depiction of the proposed conditions of the site.
Basin maps for both of the above, with hydrologic characterizations of each.
Climate data to set the design storms
Runoff calculations by a responsible and regulatory approved methodology
Routing of any storage structures, as designed on a set of construction plans (review in tandem)
Hydraulic calculations as necessary for stormwater conveyance appurtenances in the project.
Results tables / summary.
In the last 15 years, these have started to be added as well..
Water quality calculations
Operations and Maintenance plans for stormwater features
Downstream / regional analysis
What goes into a report varies widely by region, as do the accepted methodologies for the calculations.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
B+W Engineering and Design
Los Angeles Civil Engineer and Structural Engineer
http://bwengr.com
NT
Thanks for the input. This information is really helpful for a person who reviewed the report for the first time.
NT
You should understand there are high-intensity/moderate-volume/short-duration 25 year storms and low-intensity/large-volume/long-duration 25-year storms, plus many storms in between. Generally speaking, a good design is checked to both types of storms. i would suspect a storm in your study is the "25-year, 24-hour storm".
http://www.nws.noaa.gov/oh/hdsc/index.html
i don't know anything about your project to say whether 100-yr storm would be appropriate, except that given its a wind farm, you're probably not in a flood plain. i personally find very few occasions to model 100 years, but mine are usually subdivisions and commercial.... i would be more interested in seeing how the system behaves under a 10-yr 5-min storm (selecting arbitrarily). there are actually a lot of tricks that someone can do to cook the books for stormwater modeling in Hydrocad or any other software. if the time of concentration is BS, the modeling is BS regardless of the storm. If it really needs to be reviewed professionally and not just administratively, get a local site design CE and learn in the process.... By the way, there is a storm/flood forum on this site.
a) make sure your roads or culverts or anything else you are constructing does not divert runoff from the natural flow path to another path. that can cause downstream impacts to other property owners.
b) make sure your construction does not back up water and cause ponding which would affect any adjacent or upstream properties.
c) if you are in the United States, than you need to check FEMA flood insurance rate maps to determine if you are in a regulatory floodplain which is generally 100-year. just because this is a wind project has no bearing on if the road crosses a floodplain.
d) you may need calculations for erosion and sediment deposition especially at culverts and ditches
e) i assume you will need an all weather access road to the site. generally these are designed so that they are passable by emergency equipment during 100-year conditions.
Thanks for the input. It is indeed very helpful
NT
