building a field voltage monitor circuit for input to a plc
I need help designing a circuit that will monitor the field voltage of a 24 v. alternator so it will set an alarm thru a plc system when a predetermined voltage is seen. This is for a PM program to help determine when the alternator is getting to a stage in its life when it should be replaced before a failure occurs on the road.
RE: building a field voltage monitor circuit for input to a plc
1) normal operating voltage range compared to "fail" voltage level.
2) Is the alternator tested when loaded or unloaded, and also with or without the usual control circuit present?
