Insert Sheet command
I am trying to use a PAX file to control the templates available for my department, both New templates and Insert Sheet. The New template command seems to be working with my PAX file, and the Insert Sheet command shows all the templates, but will not actually load in the new sheet. If I leave the sheet PAX with only one callout, it does work however. All files are in the correct directory, and file access is granted.
Drawing PAX
Insert Sheet PAX
Is there something wrong within my PAX? or is something else going on?
Kyle
Drawing PAX
CODE -->
<?xml version="1.0" encoding="UTF-8"?> <Palette xmlns="http://www.ugsolutions.com/Schemas/2002/UGPalettes" schemaVersion="1.0"> <Presentation name="Customized" bitmap="\\shapecorp.com\k-drive\ug\title_blocks\NX8.5\Shape.jpg" FileNewTab="Shape Drawing" application="All" UsesMasterModel="Yes"/> <PaletteEntry id="d1"> <References/> <Presentation name="Metric B-Size" description="B-Size Shape Template w/ Metric Dimensions"> <PreviewImage type="UGPART" location="ShapeNX8.5\dwg_b_metric.prt"/> </Presentation> <ObjectData class="DrawingTemplate"> <TemplateFileType>none</TemplateFileType> <Filename>ShapeNX8.5\dwg_b_metric.prt</Filename> <Units>Metric</Units> <UsesMasterModel>Yes</UsesMasterModel> </ObjectData> </PaletteEntry> <PaletteEntry id="d2"> <References/> <Presentation name="Metric A-Size" description="A-Size Shape Template w/ Metric Dimensions"> <PreviewImage type="UGPART" location="ShapeNX8.5\dwg_a_metric.prt"/> </Presentation> <ObjectData class="DrawingTemplate"> <TemplateFileType>none</TemplateFileType> <Filename>ShapeNX8.5\dwg_a_metric.prt</Filename> <Units>Metric</Units> <UsesMasterModel>Yes</UsesMasterModel> </ObjectData> </PaletteEntry> <PaletteEntry id="d3"> <References/> <Presentation name="English B-Size" description="B-Size Shape Template w/ English Dimensions"> <PreviewImage type="UGPART" location="ShapeNX8.5\dwg_b_english.prt"/> </Presentation> <ObjectData class="DrawingTemplate"> <TemplateFileType>none</TemplateFileType> <Filename>ShapeNX8.5\dwg_b_english.prt</Filename> <Units>English</Units> <UsesMasterModel>Yes</UsesMasterModel> </ObjectData> </PaletteEntry> <PaletteEntry id="d4"> <References/> <Presentation name="English A-Size" description="A-Size Shape Template w/ English Dimensions"> <PreviewImage type="UGPART" location="ShapeNX8.5\dwg_a_english.prt"/> </Presentation> <ObjectData class="DrawingTemplate"> <TemplateFileType>none</TemplateFileType> <Filename>ShapeNX8.5\dwg_a_english.prt</Filename> <Units>English</Units> <UsesMasterModel>Yes</UsesMasterModel> </ObjectData> </PaletteEntry> <PaletteEntry id="d5"> <References/> <Presentation name="Dual DIM A-Size" description="A-Size Shape Template w/ Dual Dimensions"> <PreviewImage type="UGPART" location="ShapeNX8.5\dwg_a_dual.prt"/> </Presentation> <ObjectData class="DrawingTemplate"> <TemplateFileType>none</TemplateFileType> <Filename>ShapeNX8.5\dwg_a_dual.prt</Filename> <Units>Metric</Units> <UsesMasterModel>Yes</UsesMasterModel> </ObjectData> </PaletteEntry> </Palette>
Insert Sheet PAX
CODE
<?xml version="1.0" encoding="utf-8"?> <Palette xmlns="http://www.ugsolutions.com/Schemas/2001/UGPalettes" schemaVersion="1.0"> <Presentation name="Sheet Templates" bitmap="drawing_new.bmp" FileNewTab="" application="All" UsesMasterModel="No"/> <PaletteEntry id="d1"> <References/> <Presentation name="Metric B-Size_NewSheet" description="B-Size Shape Template Sheetw/ Metric Dimensions"> <PreviewImage type="UGPART" location="ShapeNX8.5\dwg_b_metric_ns.prt"/> </Presentation> <ObjectData class="SheetTemplate"> <TemplateFileType>none</TemplateFileType> <Filename>ShapeNX8.5\dwg_b_metric_ns.prt</Filename> <Units>Metric</Units> </ObjectData> </PaletteEntry> <PaletteEntry id="d2"> <References/> <Presentation name="Metric A-Size_NewSheet" description="A-Size Shape Template Sheet w/ Metric Dimensions"> <PreviewImage type="UGPART" location="ShapeNX8.5\dwg_a_metric_ns.prt"/> </Presentation> <ObjectData class="SheetTemplate"> <TemplateFileType>none</TemplateFileType> <Filename>ShapeNX8.5\dwg_a_metric_ns.prt</Filename> <Units>Metric</Units> </ObjectData> </PaletteEntry> <PaletteEntry id="d3"> <References/> <Presentation name="English B-Size_NewSheet" description="B-Size Shape Template Sheet w/ English Dimensions"> <PreviewImage type="UGPART" location="ShapeNX8.5\dwg_b_english_ns.prt"/> </Presentation> <ObjectData class="SheetTemplate"> <TemplateFileType>none</TemplateFileType> <Filename>ShapeNX8.5\dwg_b_english_ns.prt</Filename> <Units>English</Units> </ObjectData> </PaletteEntry> <PaletteEntry id="d4"> <References/> <Presentation name="English A-Size_NewSheet" description="A-Size Shape Template Sheet w/ English Dimensions"> <PreviewImage type="UGPART" location="ShapeNX8.5\dwg_a_english_ns.prt"/> </Presentation> <ObjectData class="SheetTemplate"> <TemplateFileType>none</TemplateFileType> <Filename>ShapeNX8.5\dwg_a_english_ns.prt</Filename> <Units>English</Units> </ObjectData> </PaletteEntry> <PaletteEntry id="d5"> <References/> <Presentation name="Dual DIM A-Size_NewSheet" description="A-Size Shape Template Sheet w/ Dual Dimensions"> <PreviewImage type="UGPART" location="ShapeNX8.5\dwg_a_dual_ns.prt"/> </Presentation> <ObjectData class="SheetTemplate"> <TemplateFileType>none</TemplateFileType> <Filename>ShapeNX8.5\dwg_a_dual_ns.prt</Filename> <Units>Metric</Units> </ObjectData> </PaletteEntry> </Palette>
Kyle
CAD Detail and Designer II
NX 7.5, 8, and 8.5 with SmarTeam Integration.
CATIA V5 R20-R22
RE: Insert Sheet command
Do you get any sort of error message?
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.2, NX10 Beta
CODE
CATIA V5 R20-R22
Kyle,
Two questions:
Have you tried temporarily adding one of the NX OOTB template parts to the pax file to see if those parts work from this pax file?
Have your template parts been marked as templates? ("Menu -> Tools -> Drawing Format -> Mark As Template...")
Joe
I just verified, the templates are marked as templates, and if I try to insert a A0-A3 (NX default) sheets in my PAX, they work great.
Thanks.
Kyle
CATIA V5 R20-R22
I just copied some templates I have, renamed them and put them in a ShapeNX8.5 folder so I didn't have to make any edits to your pax.
I can only surmise from that, that the PAX file is ok. To me it's either your environment or template files.
Can you post your log again from a session where you try and add your sheets, just make sure this time that you post more of it (before and after where the template is added).
Usually the bit I'm interested in is before what you posted.
Anthony Galante
Issue resolved. Thanks for everyone's help!
Kyle.
CATIA V5 R20-R22
