INSERT CURENT DATE INTO TEXT
ok i want set a button or something to place or replace the date or the following text ?month? dd, yyyy with the corect current date
any body done this before
if everyone helps everybody the world will be a better place
RE: INSERT CURENT DATE INTO TEXT
Try some form of this:
; Routine:       C:TODAY
; Description:   Places current date text in selected location
(defun c:today (/ layer ts ip)
  (setq ip (getpoint "\nInsertion Pt: "))
  (command "text" ip (getvar "textsize") "0"
    (strcat (substr (rtos (getvar "cdate")) 3 2) "/"
            (substr (rtos (getvar "cdate")) 5 2) "/"
            (substr (rtos (getvar "cdate")) 7 2)
  (princ)
);end c:today function
Tim
Ok but what about an existing peice of text or block attribute???
I use 2 different files one that updates the date and time. Both of those are separate attibuted blocks and only the ones in the current drawing tab get updated.  The other file updates the date and time attributes built into a title block.  If any of these interest you send me an email: smotichek@projectconsulting.com.
If you want to update a title block, let me know what the attribute tag is for the date and the format for date and I'll send it to you.  The format for the date is currently MM-DD-YY and the time is in military.
SEMott
Stephen E. Motichek
Project Consulting Services, Inc.
