Portable Generator Input Receptacle
I am seeking the name of a manufactured 400A 480/3 input device which would include both camlock receptacles and landing lugs, to receive the output of a portable engine-generator. Purpose is to bypass the local fixed engine-generator in the event of failure or maintenance downtime. I had expected this to be an easy find, but I'm stumped. The application is in a technically-challenged region; I hope to avoid designing a field-assembled package. Thanks!
RE: Portable Generator Input Receptacle
Here's an option: http://www.meltric.com/pdfs/2013-2014-catalog/2013...
And others: http://www.emersonindustrial.com/en-US/documentcen...
http://www.powercabling.com/documents/Russellstoll...
If this is in US, contact Hubbell and/or Appleton. I think they have standard 400 A/600 V units. That's about the maximum I've seen though.
You'll want to be sitting down when you check the prices, sizes and weights of these monsters.
