UNS G41300 material
UNS G41300 material
UNS G41300 material
HI Frds,
I am working in valve industry.
UNS G41300 is a alloy steel. i have seen ,many oil and gas company is used UNS G41300 material in valve body.
i cound not found it in ASME Section II , and also ASME B16.34 material table.
Is it because of general service material?
How can find yield strength related to temperature service . or i can take yield strength at room temperature in my calculation?
RE: UNS G41300 material
This thread may answer your question about ASME.
Title: P-Number for 4130?
Thread: thread292-197673: P-Number for 4130?
Basically ASME does not endorse it.
MatWeb.com lists it closest to 4130 but I am not familiar with the material beyond this.
Good Luck
i think you might see API TR 6MET.
i'm working on wellhead industry in which i use 4130 (UNS G41300) a lot for wellhead equipment.
In wellhead equipment, valve is also considered as part of it.
anyway, im not sure what you're looking for or even if ASME provide those information somewhere,
but i've seen those standard shows decreasing mechanical properties with respect to increasing service temperature.
both in experiment data and graph.
hope this helps.
yudhi
If you're at any significant temperature, don't just take room temperature to design with. For low alloy steel along the lines of 4130/4140, we usually use a 90% yield strength derate for 300°F.
Any hard data you find will have a decent variance from lot to lot. One mill run may derate 92% at 300°F, while the next might derate 88%. Generally the data you see in graphs averages that to 90% for 300 °F, and that's generally safe to design with if you use standard safety factors on your allowable stresses.
The YTS for 4130 alloy steel versus temperature will vary based on the HT condition of the 4130 and the temperature it is subject to. It will make a difference in how much the 4130 material strength changes with temperature depending on whether it starts as annealed or quenched and tempered.
I've attached a chart from MMPDS-01 for 4130 tensile strength vs temperature.
