Load Bearing capacity for Bolts
Can anyone let me know how to find the load bearing capacity for M24 Bolts?
Material: CS Gr 8.8
Material: CS Gr 8.8
RE: Load Bearing capacity for Bolts
try this link
http://www.roymech.co.uk/Useful_Tables/Screws/Scre...
Thanks for the information.,
Well the steel used to manufacture fasteners is generally a medium carbon steel I on our bills of material we only ever specify the grade 8.8,4.6 etc so I suppose the short answer is yes.
Well the tension acts longitudinally in the fastener parallel with the shaft axis but shear acts at ninety degrees to the shaft axis.
see this site:- http://www.roymech.co.uk/Useful_Tables/Screws/Bolt...
If you can explain in more detail exactly what your looking for we can give more detailed answers but your questions are so vague its down to our interpretation
Actually we have been asked to quote the pipe clamps along with the Bolts/nuts and the load has been stated in the drawing itself.,We have considered M24 instead of M25 as shown in the drawings and now the client is asking for the load capacity of these bolts.
