Widening bolt holes due to too large of gasket
Is it ok to widen bolt holes 1/8" too allow for a gasket to fit between flanges? Does this lead to uneven stress? I have a large 20" plus line with a metal gasket that is approximately 3/16" too wide to sit in between the bolts. I would like to widen all bolt holes slightly to seat the gasket in between the bolts. When we pulled the previous gasket it was noticed that the outside of the gasket had rolled some due to bolts being forcefully put in.
RE: Widening bolt holes due to too large of gasket
And you would ruin that machined flange to fit a 18.00 dollar gasket?
Get the right gasket.
Use the right bolts.
Use the right torque applied the right way at the right intervals.
I worked at a place one time (it was a LONG 3yrs) where they had no dimensional inspection equipment. If a design didn't fit the upper management poked the design engineers and told them to fix the problem. They would not pay for the parts to get fully dimensionally inspected by a third party nor did their ever-tight schedules allow the parts to be returned to get reinspected by the fabricator. Hence, the design engineers were stabbing in the dark and providing solutions that made the parts fit. This was the same place where the production line workers would publicly put down the designers if the parts didn't self-assemble when you threw them in the air! Like I said. It was a long 3yrs. They got bought by a big company and soon the doors were shuttered and people were told they no longer had jobs!
Tunalover
