Dynamic Shear Modulus vs. Static Shear Modulus
I'm being asked to design a footing for a piece of vibrating equipment and the geotechnical report gives no dynamic soil properties. The goetechnical engineer completed their work over 3 years ago, long before my firm was even hired, and there's no way the client will pay for further geotechnical investigation at this stage.
Question #1: The geotechnical report does however give static soil properties. The area is primarily meta-sandstone. I'm looking for a formula that relates the dynamic shear modulus of rock (specifically sandstone) to the static shear modulus. Is there such a thing?
Question #2: The static shear modulus is given in the report as 80 MPa. Does that seem to be in the ballpark?
RE: Dynamic Shear Modulus vs. Static Shear Modulus
DCBII, do you have the results of any geophysical survey in the area? with a Vs (sher wave velosity) value? The 80 MPa value doesn't sound unreasonable, we usually define a Gmax or G0 which means G at small deformations (usually measured by geophysical means), then we should apply a degradation scheme which is different in dynamic and static conditions. So if your G is a G0 there might be no degradation depending on the machine, otherwise a totally approximate way to degrade is to apply a 0.5 factor, which is also applied to static degradation.
Bottom line, does the report specify Gmax or G0 or just G static? To be more precise, a static G should have an 'operational' label which means it has already been degraded
It calls it an "Estimated Static Elastic Shear Modulus". It does not specify whether or not it's been degraded. I do have a seismicity report, which gives a response spectrum for a shear wave velocity of 1800 m/s, but I don't think that's necessarily the shear wave velocity on site. Typically the response spectrum values are generic and need adjustment using coefficients to suit actual site conditions.
Hello, i am curious have you fixed the problem ?
Dear friends, u can use limit analysis for your work. in this method there is no need to use young modulus and shear modulus. u can download basic information from this link: uploadboy.com/aoxq7tmmzq3u.html
