Robot not moving forward while the wheel rotates in MSC Adams
I have a simple test problem (my first simulation with MSC Adams).
There are 4 solid parts including:
1) 2 wheels (RigidBody: Cylinder)
2) 1 link (RigidBody: Link)
3) 1 terrain (RigidBody: Box)
Three Joints:
1) 1 Revolute joint between the first wheel and the link
2) 1 Revolute joint between the second wheel and the link
3) 1 Fix joint between the ground and the box
Two Contacts using Impact normal force option and Coulomb friction force option:
1) 1 contact between the first wheel and the box
2) 1 contact between the second wheel and the box
One Joint motion:
1) Rotational (Default Function (time) : 30.0d * time) on the first joint between the first wheel ant the link.
The problem is that the first wheel rotates but the robot does not translate. What could be the source of that type problem?
Three Joints:
One Joint motion:
RE: Robot not moving forward while the wheel rotates in MSC Adams
Cheers
Greg Locock
I think that I might remove the gravity with the first model simulation.
Kab.
