Cutting .316 stainless with oxygen
I have a Mazak Champion and having problems cutting .316 stainless. Poor cuts with dross. I'm using a 2mm nozzle. Any suggestions as to what is going on?
RE: Cutting .316 stainless with oxygen
Make sure you have enough nitrogen pressure at the nozzle. Focal point is also important; long sharp burr means focal point is too high. Small burr means focal point too low.
