Alert - Feature applied to different bodies since the last update
I'm a new NX user, in 8.5. I'm getting an alert on an extrude feature, that is created from a sketch and extruded to the next face, which is a sweep from a sketch. The alert is, "Feature applied to different bodies since the last update". I don't recall editing any of the parent features, although I guess I might have. Would that cause the alert? Is there any other way it would show up?
I can't figure out how to clear the alert, except for going into the extrusion, changing the parameters (from Until Next to a value), and then changing them back. Is there a better way to do that? The text of the alert makes me think there's some sort of Update command.
Thanks in advance!
Thanks in advance!
RE: Alert - Feature applied to different bodies since the last update
www.nxjournaling.com
The problem once, I cleared the alert but it kept coming back. Also tried tools > update > update model but it wouldn't go away.
Think in the end I ended up changing the boolean and then changing it back to get rid of it.
A curious one.
www.jcb.com
NX 8.5 with TC 8.3
