Plate Buckling
Plate Buckling
I have been racking my brain over a problem that involves plate buckling. I have found the critical buckling stress formula by Timoshenko however I need to determine if there is something more practical out there. I essentially would like to know if there is a way to determine the buckling capacity of a cantilevered thin plate with a point load on the end. Will that plate globally buckle, is it LTB.
RE: Plate Buckling
RE: Plate Buckling
RE: Plate Buckling
euler does not address local buckling, "crippling".
Quando Omni Flunkus Moritati
RE: Plate Buckling
RE: Plate Buckling
