Change drafting sheet name to attribute
Currently all of my new drafting sheets come in as Sheet "Sheet 1". Is there anyway to get this to show up as an attribute-1 instead? So if I had an attribute with a value of BODY, my sheet names would be:
BODY-1
BODY-2
and so on. Is this possible?
Matt
BODY-1
BODY-2
Matt
RE: Change drafting sheet name to attribute
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.2, NX10 Beta
www.nxjournaling.com
I've tested in NX5 and NX9 and there is no way I can find to use an attribute for the sheet name.
Any of the ways I know for adding an attribute for the sheet name are rejected with an error (see attached image).
What you may be referring to is the customer default for specifying the default sheet name (also in the attached image as to where that is set).
Anthony Galante
