dam Safety review
dam Safety review
In the jurisdiction you practice, who does assign (contract)a review engineer for Dr of dam with significant to extreme failure consequences. Iambic interested in answers from practitioners from the US, UK, Canada, Switzerland and Japan, if possible.
RE: dam Safety review
(Sorry for typos in the original question)
the state or FERC regulates the dam
they feel that there is a deficiency
the owner is required to address the deficiency
the owner either does it himself or hires a consultant to assist
case 3
the state does not regulate the dam
the owner feels that there is a deficiency
not sure what you mean by a "review" as most regulated dams have a license to operate and that not only requires a permit application and fees, but also requires a variety of things including as-builts and specs, engineers reports, geotechnical data, emergency action plan, inundation mapping, O&M manual, current and annual inspections etc. If something is missing out of the file, than it must be provided by the owner or the license to operate will be revoked and the dam could be removed or breached.
My intention is comparing experience of dam engineers in the US, Canada, UK and Switzerland on how they hire a review engineer for a DSR.
Georgia Safe Dams Act:
http://rules.sos.state.ga.us/cgi-bin/page.cgi?g=GE...
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
Mike McCann, PE, SE (WA)
I am also eager to know answer to your question.
Apparently they do kind of _ dam safety review _ in WA. But do not know what its scope is and how it would differ from annual reviews.
Glad I don't live downstream.
Is the problem on safety legislation and frequency of inspections or are you referring to overlooked technical matter(s)?
each US state has a dam safety program (except Alabama which does not...). they license all non federal and non FERC dams. The feds handle their own dams and all hydro dams are licensed by FERC. However, the federal and FERC dams also get annual inspections and reviews, which are required by federal statutes and rules.
in general, all dams in the US have had a phase 1 assessment performed (by the USACE) as a result of the national dam safety act which was triggered by the failure of Teton Dam. As a result of the dam safety act, each state was made responsible for safety of dams. In general all state dam safety programs require annual dam inspections (which also includes a desktop review of the hydrology, structural, geotechnical and other engineering analysis of the dam). The inspection and review is done on all regulatory dams, not just large or high risk ones. Based on the results of the state annual inspection and engineering review, the state makes a decision to deem the dam safe or unsafe. So, on an annual basis, the state licensing requirements are reviewed and must be met in order to continue to operate the dam. if they don't meet the requirements, most states have the statutory authority to breach the dam.
in general, of the states I have worked with, there is no specific requirement for a instead, the state agency does their own review in conjunction with the annual inspection. if the state determines that a dam is unsafe, either emergency or non-emergency status, than the owner is required to either submit engineering analysis proving the dam is safe, or repair the dam.
http://www.damsafety.org/
Many thanks for your interesting comments. Just another question based on the following quotes of yours.
..the federal and FERC dams also get annual inspections and reviews
..the state agency does their own review (by whom) in conjunction with the annual inspection (by whom)
In the matter of conflict of interest, could you elaborate who assigns an engineer to do the annual inspections. Is the engineer assigned by the regulatory agency (state, federal) or by the owner of the dam?
the dam owner is required to have an O&M manual and an emergency action plan with inundation mapping. These are also submitted to the state for approval. Both of these documents may require additional owner inspections and monitoring. The owner can hire anybody to do any inspection or engineering analysis they want.
their is no conflict of interest that I can see.
In another jurisdiction (non US)that I am aware of, the regulatory agency asks the dam owner to assign an engineer for (annual) inspections and reviews. The owner would then submit the inspection/review report to the regulatory agency to convince the regulator that the facility is safe. The regulatory agency does not assign an engineer by itself but would approve the report. This is prone to a conflict of interest.
I wonder if my understanding of your comment is right that in the US practice, the regulator hires the inspection/review engineer. I.e. the regulator pays for the (annual) inspection/review from public sources. This may be justified as the regulator is safeguarding the public interests (so that people do not hesitate to live in the d/s areas). Thanks again.
USACE, Natural Resource Conservation Service, and Bureau of Reclamation generally do their own dam engineering. USACE engineering staff are mostly spread out among district offices, although they recently (5? years ago) started up a center of dam and levee expertise called the Risk Management Center. They provide some oversight and consistency among districts.
Reclamation's engineering staff that do dam safety studies are mostly concentrated in one office, which operates much like a captive consulting firm. Inspections for Reclamation dams are annual; complete reviews of design, performance, changes in the state of practice, etc. are done once every 6 years. Generally, there are two or more lines of internal review, including a board of finicky old men and women (generally PEs and PGs with 20-30 years experience), and for more complex problems, a board of outside hotdogs may be hired (names you would recognize - Ralph Peck and Harry Seed were among the favorites.) There is enough separation of engineering and dam-safety management that the process can become adversarial, but mostly that's good, because it forces everyone to have their technical arguments spelled out in detail for examination.
Smaller agencies are more likely to hire a consultant, or another federal agency with more engineering staff to act as a consultant.
This is now in addition to the annual inspection. I do not know what do they call this complete review. One may call it dam safety review every six years. But from one of the comments I thought there are no periodical systematic reviews for dams except the annual inspections. Coming back to my original question, I guess this 6 yearly reviews are done by regulatory agency not by the owners.
I would appreciate further clarifications, if possible.
I don't think most privately owned dams get that kind of scrutiny, except hydropower dams licensed by FERC. State requirements vary quite a bit from state to state.
