Turn mesh off in results?
I'm using NX8.5 Advanced Sim Nastran and would like to know... Is there is a way to turn the mesh off in the results?
Thank you
Thank you
RE: Turn mesh off in results?
If no mesh, no results!. Surely you want to hide "element edges" to easily show results, don't you?.
1.- Plot any result in the screen.
2.- Right-click the post view node in the Post-Processing Navigator and choose Edit, or click Post View on the Post Processing toolbar.
3.- In the Post View dialog box Display page, select Color Display, and select from Smooth, Banded, Element, Iso-line or Iso-surface.
4.- Click Result.
5.- In the Set Result dialog box, specify the mode/iteration/load case, results set, and data component as needed. For element displays, specify the element criterion.
Here you are the types of contour plots you can create in NX AdvSim Postprocessor, my favorite is BANDED CONTOUR PLOT:
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48004 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
