Flammability of fuels
Hi readers,
Please can someone help me out with interpreting LFL and UFL values
I have UFL values of 1.00E+06 ppm which is about 100% of it, what does this mean?
Can I still consider the mixtures to be flammable?
Some have LFL values and then UFL of this value but some of them do not have any LFL values just the UFL of 1.00E+06 ppm
RE: Flammability of fuels
A LFL of 0 would be a similar situation.
I'd like to know what materials you are dealing with. H2 has one of the widest ranges I'm familiar with.
The mixture I am dealing with comprises of hydrocarbons (C1 to C10) and water. I am working on flammability of HC mixtures with water, to investigate the point at which it can be considered non-flammable
C1 through about C4 are gases at room temperature. They are sparingly soluble in water and come out of solution as soon as the pressure is let down, concentrating in the air space above the water. Surfactants aren't going to stop that from happening.
C5-C10 are liquids at room temperature, are all sparingly soluble in water (perhaps a few hundred ppm at most), and are all less dense than water, and so tend to form a film or sheen to a separate layer on top of water when allowed to contact with air- unless they are thoroughly emulsified.
In any case- dissolved gas, emulsified liquid or free product, you're dealing with pure component vapour pressures to determine what matters, i.e. the air/fuel mixture concentration in the headspace. It's as if the fuel and the water were in separate containers inside a common air space. Even in an emulsion there is no true solvation- you just have stabilized droplets of free product liquid hydrocarbon with its surface made "friendly" to the water by the surfactant. You get zero benefit from the presence of water, i.e. no vapour pressure suppression to reduce the concentration of flammables, other than by the presence of water vapour as an inert.
Its a crude oil sample composition ,includes small proportions of N2, H2S and CO2 also and I am modelling with the consequence model tool which is giving results for pool fires.
Trying to understand the chemistry of this interaction of the components and its effect on flammability because at some point the mixtures are non-flammable with about 95% water by mass
you must get smarter than the software you're using.
