Registration of Pressure Vessel / Heat exchanger / Compressor in Singapore
Appreciate your help to explain the basic requirement to register and inspect for pressure vessels, in terms of minimum pressure etc.
We have an evaporator that consists of a boiling chamber which is in vacuum state. It is used to evaporate wastewater at flash evaporation of around 40degC.
The wastewater is initially heated by a heat exchanger and a compressor (using a refrigerant).
After which the distillate from this evaporation goes to another distillate storage tank for overflow discharge to other uses. The concentrate will also go to a concentrate storage tank for further offsite disposal.
In short, do we need to register with MOM Singapore for the boiling chamber, heat exchanger and compressor?
Many thanks in advance!
