Magstar N50 Demagnetization Curve
Does anybody have the demagnetization curve of the permanent magnet "Magstar N50" (although it is old), because I am trying to match a new simulation with an older one from anther source that uses this permanent magnet.
Thank you in advance.
RE: Magstar N50 Demagnetization Curve
Is it a NdFeB 50 MGOe material? If so, it's pretty common and you can find it from practically any reputable permanent magnet supplier.
Thank you, I have already used this permanent magnet. But as I mentioned above, I am trying to reproduce an old simulation that uses that specific permanent magnet "Magstar N50".
So is there anyone who worked with this old type of permanent magnet before and can share its demagnetization curve?
Thank you.
N50 commonly means NdFeB magnet material, 50 MGOe. MagStar is/was just a reseller and 50 MGOe material is pretty common.
A 50 MGOe material from Vendor A is going to be nearly exactly the same as 50 MGOe from Vendor B.
OK, thank you.
So do you have its demagnetization curve?
Issam: The link in my earlier post displayed the demagnetization curve for N50
Thank you all.
