GD&T for a hollow sphere...
I'm new to GD&T and currently have an assignment to work on. Basically, I have a hollow spherical shape but the sphere itself is elongate at both ends (distal and proximal), each end has a different dimension. The overall diamter is important. What I did was give a radius of R.945 (D = pi * R^2) which gives a diameter of 1.79". My question is, can I have this radius as a REF (R.945 REF) and then have the sphere as basic dimension, that is a total length in diameter and total length in height. What symbol of GD&T I need to add in the radius to ensure the parts come out as a sphere? Please help and let me know.
Paul
RE: GD&T for a hollow sphere...
SR (meaning spherical radius) is the GD&T symbol you need.
What you are describing is not a "sphere" (think marble or ball bearing).
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
Sphere usually doesn't have an end, not to mention "both ends"
How about some sketch?
You have a think that is not a sphere, but you are asking how to dimension it so that it is a sphere.
Please explain what you need to accomplish. Not how you think it should be done.
The center axis of the part could be referenced as Datum A.
Seems like you could apply a Profile to datum A to the outside of each wire in your basket (note, I don't see thickness controlled on your print either) and change the "8X R.945 REF" to a basic dimension. The end result is a sphere, but it seems that controlling them as individual radii would provide the same level of control.
Be careful not to over-tolerance. Wire baskets rarely follow a completely spherical pattern.
Please add a cross-section of the members to your drawing, then re-post.
Jim Sykes, P.Eng, GDTP-S
Profile Services www.profileservices.ca
TecEase, Inc. www.tec-ease.com
