existing FRP tank needs penetration above water mark
Have a small community water system with an existing atmospheric horizontal capsule-shaped or pill-shaped 8,000 gallon FRP tank. We're doing some upgrades to the distribution system and want to include adding a 2" penetration to make an overfill line for the storage tank. i'm curious if there are gasketed fittings out there and if the community has crossed this before and handled it differently. Also interested in procedures if necessary to make the penetration. we have a manway at the top, a 3" normal vent opening at the very top of the tank, a 2" nozzle outlet at the bottom, and a 1" nozzle above the high water mark.
RE: existing FRP tank needs penetration above water mark
The other option that I think could be used is a spin-welded fitting, but I haven't used those myself. That would eliminate the need for the gasket but would need a flat surface to attach to the tank on.
