Drafting, Layers visibility
In Model some layers are hiden
In Drawing Hiden layer are displayed (actually all layers are displayed)
How to HIDE in drawing the layers which are Hiden in model ?
RE: Drafting, Layers visibility
I work in NX-7.5
Format -> Layer Visible in View, then click the Reset to Global so it cycles through the sheet and the views.
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.2, NX10 Beta
and when you place the view on the drawing; if there are layers set as invisible (in the normal layer menu) then in "visible in view" they will be set to invisible until you change it for that view
Works, thanks a lot
