Using Pattern Feature with two axes
Greetings all!
I have an interesting question for the NX9. Attached is a rough kinematic sketch of a machine. This is one of many kinds of a pump. It has two parts which rotate together and few cylinders which move relative to those parts. If you change the vlaue or animate the 'Driver' dimension, you will understand what I mean.
So the question is - is it possible to parametrise the number of cylinders using the Pattern Feature method? I could not make it work, because there are two axes involed in this pattern, not one. Any ideas?
Industry creates wealth!
RE: Using Pattern Feature with two axes
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Here's the revised model. You may safely disregard the particular feature tree, and model is not even fully parametric, but the design intent is there.
Basically, we have a circle and a cylinder. Both circle and cylinder are divided by the equal number of even spaces - seven in the present model. Point on a circle and a corresponding vertical trace on a cylinder are connected by a red line - I call it 'slider'. Slider has defined length, which actually controls how high or how low it ends up on the cylinder. All sliders are equal in length.
Now the question - is it possible to parametrise the number of sliders using Pattern Feature? So that we could change the expression controlling the number of sliders, and the whole thing would update. I haven't yet came up with the solution.
