High Frequency Power Generator
I am testing a board and need to generate 1 watt power at 100 KHz and 11 volts. Please advise.
RE: High Frequency Power Generator
If you need a sinusoidal output then most small audio power amps are capable of 100kHz if you adjust the deliberate high-frequency roll-off point. If you need a square wave then the harmonic frequencies required will be over 1 MHz, which is beyond the reach of most audio amps. You haven't provided sufficient information to answer your question.
