Mitigant for high rates of gas bubble and fluid expansion in a VST
Greetings,
Please, what could cause high rate gas bubbles and fluid expansion that highly exaggerates the meniscus of liquid level on the sight glass of a vertical surge tank (VST) during a well testing operation, and what can one do in detail to mitigate this condition that gives an erroneous tank factor.
thanks
thanks
RE: Mitigant for high rates of gas bubble and fluid expansion in a VST
thank you for your idea, however, what i need is more like a design solution or an operation solution that would affect the activity in the entire vessel, as you know, the sight glass represents a cross section of the vessel of the VST as well as the activities(oil expansion and excessive gas bubbles) in it, which a little opening of the lower valve would not stop these activities. again, when acquiring our meter and shrinkage factors that it determined with time, how do i factor the communication delay of the level indication between the vessel and the sight glass/guage?
thank you
