Link to Configuraition Name
I'm trying to link a text note in a drawing to the configuration name from the model in view. This is probably a simple task, but I can't get it to work. I'm using Solidworks 2001plus, please help.
RE: Link to Configuraition Name
Just make a CUSTION PROPERTY (call it CFGNAM or something), then make your cell = to the first column in your table.
Then, in your TEXT NOTE, you can link to the CGFNAM you just made.
There may be a slicker way to do this, but without investigating I can tell you for sure this will work.
