SW doesn't open files directly from Windows Explorer
RE: SW doesn't open files directly from Windows Explorer
Right click on the file in windows explorer. Click on "properties"
What does it say under "Opens with"
Maybe it's looking for an old version of Solidworks?
David
Check out my professional profile and connect with me on LinkedIn. http://lnkd.in/fY7-QK
Hi, nidmus:
I have the same issue as yours.
Good luck!
Alex
there's no solution ??
I rarely use that open method anymore, simply because mine opens up a new SW window for every file. I just simply drag and drop the file in SW and it opens fine.
Have tried contacting your VAR, because obliviously we have not found an answer or we have not pursued this with our VAR. If your VAR does have a solution that works you should post it here.
Scott Baugh, CSWP pc2
www.superATV.com
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
