Dimensions become un-associated after using visible in view
We've just upgraded from NX6 to NX9.
Frequently, we create dimensions associated to an underlying Sketch. We then use Visible in View and make the Sketch layer invisible. The dimensions initially remain associated. However, if a View Update is performed then the dimensions become un-associated.
Does anyone know what version this behaviour changed ?
NX 9.0.2.5 (Desperate for 9.0.3)
NX 10 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
RE: Dimensions become un-associated after using visible in view
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
I guess it's related somehow, but when you use a manual boundary to crop geometry, dimensions also become un-associated.
NX 10 (Testing)
You have to select that while placing.
I'm expecting this behavior hasn't changed in NX9.
Mechanical Engineer
NX8.5.3 / TC9.1.2
When using "Exact”, lines and arcs are not capable of automatically triggering a view update.
GTAC have advised to stay with "Exact (Pre-NX8.5)",
NX 10 (Testing)
