Fatigue analysis with pressure fluctuation only
Dear all,
I have a drum with temperature in conctant, but pressure changes in a cycle from 200 psig to 50 psig, then back to 200 psig.
Vendor is using the pressure difference of 150 psig to run the Von Mises stress, then based on Div 2, Eq 5.29 to calculate the stress range and then determine the fatigue cycles.
Questions:
1). Is it correct just by using pressure difference for fatigue analysis ?
2). Is it correct just by using pressure difference to calculate pressure thrust acting at the nozzle?
Questions:
RE: Fatigue analysis with pressure fluctuation only
