Density in Pro-e
Density in Pro-e
I am trying to put in Density in for material.
I have entered the following
Name = PTC_MASS_DENSITY
Type = Real
Default = 7.3424e-04 lbf sec^2/in^4
Access = Full
into the steel.mtl but when I use it in a part the density doesn't come up correct.
Is there something else that needs to be modified other the the PTC_MASS_DENSITY?
Type = Real
Access = Full
RE: Density in Pro-e
If this doesn't solve your problem, we may need more information as to what exactly you are doing.
