Gather results during parametric study
Hello everybody,
I am working on a quite big parametric study simulating effects of different loads and fiber orientation in the material on a carbon fiber prop-shaft.
I already have a phyton script for a parametric study, however I have problems with extracting the results.
I want to have results over a circumferential path around the shaft. (about 60 elements)
Is it possible to do it with "gather" function? I think only one node/element can be selected with "gather" command.
I have considered a for/while loop, but the results will be written separately and I want a single table.
I cannot use phyton scripts for each of the .odb files after the study because the number of them will be too high. (I have 5 parameters, that are changing - I am dealing with cca 2000 simulations)
Has anyone done this before or has been dealing with this problem?
Thanks for your help,
Best regards,
Gasper
Best regards,
Gasper
RE: Gather results during parametric study
If the geometry is constant, just get the element id's - either by using a path or a set that contains the element id's.
Regardless of the number of ODBs, it would still be viable to traverse each odb and drop the desired results into
a global table. Run time is the only concern. Test it on a few first to reduce run-time while developing.
Hint:
globalResultTable = []
for odbName in glob.glob('*.odb'):
Hope this helps....
Ebbe
