nx journal to create Index number at dimension with adjusted orientation
I am trying to create an Index number to a selected dimension. For this I found a very helpful journal in this forum that I modified a bit. Now I need to adjust the text angle of the ID Symbol to match the diminsion's orientation. Dimensions do not have a lettering angle in the style dialog like notes. Therefore I wanted to use the TextOrienationAngle from the dimension.
But I allways get an error:
"Line 56: "GetDimensionPreferences" is not a member of "NXOpen.Annotations.Annotation"
Can anyone help me on this problem?
CSchnei
CODE -->
'journal to Create Non- Associative Index Numbers at Dimensions or Notes
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Imports NXOpen.Annotations
Module NXJournal
Sub Main
'change the following offset distances to get something that works for you
'offsets from dimension text
Const XOffsetDim as Double = 0
Const YOffsetDim as Double = 2
'offsets from notes
Const XOffsetNote as Double = -3
Const YOffsetNote as Double = 0
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim lw As ListingWindow = theSession.ListingWindow
Dim noteDim As Annotation
Dim noteDimOrigin as Point3D = Nothing
Dim letterPref as LetteringPreferences = Nothing
Dim symbolPref as SymbolPreferences = Nothing
Dim dimpref as DimensionPreferences = Nothing
Dim noteNumber as Integer
Dim letterangle as String
Dim dimangle as String
Dim input as String
Dim theAnnotationManager as NXOpen.Annotations.AnnotationManager = workPart.Annotations
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start")
Do
input = InputBox("Enter starting INDEX number: ", "Create Index Numbers at Dimensions or Notes", "")
Loop Until (isNumeric(input))
noteNumber = input
lw.Open()
While selectNoteDimension("Select Dimension or Note", noteDim) = Selection.Response.Ok
noteDimOrigin = noteDim.AnnotationOrigin
'lw.WriteLine("origin: " & noteDimOrigin.X & ", " & noteDimOrigin.Y)
letterPref = noteDim.GetLetteringPreferences()
letterangle = letterPref.Angle
dimpref = noteDim.GetDimensionPreferences()
dimangle = dimpref.TextOrienationAngle
'symbolPref = NXOpen.Preferences.AnnotationPreferences.GetSymbolPreferences()
symbolPref = theAnnotationManager.Preferences.GetSymbolPreferences()
'lw.WriteLine("Alignment Position: " & letterPref.AlignmentPosition.ToString())
'lw.WriteLine("ID Symbol size: " & symbolPref.IDSymbolSize)
'lw.WriteLine("Annotation type: " & noteDim.GetType().ToString())
Dim nullAnnotations_IdSymbol As Annotations.IdSymbol = Nothing
Dim idSymbolBuilder1 As Annotations.IdSymbolBuilder
idSymbolBuilder1 = workPart.Annotations.IdSymbols.CreateIdSymbolBuilder(nullAnnotations_IdSymbol)
idSymbolBuilder1.Origin.Plane.PlaneMethod = Annotations.PlaneBuilder.PlaneMethodType.XyPlane
idSymbolBuilder1.Type = Annotations.IdSymbolBuilder.SymbolTypes.Circle
idSymbolBuilder1.UpperText = noteNumber
'use the symbol size set in the part
idSymbolBuilder1.Size = 4
idSymbolBuilder1.Style.LetteringStyle.GeneralTextSize = 2.5
idSymbolBuilder1.Style.LetteringStyle.Angle = dimangle
Dim assocOrigin1 As Annotations.Annotation.AssociativeOriginData
Dim nullPoint As Point = Nothing
Dim nullView As View = Nothing
With assocOrigin1
.OriginType = Annotations.AssociativeOriginType.OffsetFromText
.OffsetAnnotation = noteDim
.OffsetAlignmentPosition = Annotations.AlignmentPosition.TopRight
.AssociatedPoint = nullPoint
.StackAlignmentPosition = Annotations.StackAlignmentPosition.Above
.AlignedAnnotation = Nothing
if noteDim.GetType().ToString() = "NXOpen.Annotations.Note" Then
.XOffsetFactor = XOffsetNote
.YOffsetFactor = YOffsetNote
Else
.XOffsetFactor = XOffsetDim
.YOffsetFactor = YOffsetDim
End if
End With
Dim point1 As Point3d = New Point3d(noteDimOrigin.X-4, noteDimOrigin.Y+6, 0.0)
'idSymbolBuilder1.Origin.SetInferRelativeToGeometry(True)
'idSymbolBuilder1.Origin.SetAssociativeOrigin(assocOrigin1)
idSymbolBuilder1.Origin.Origin.SetValue(Nothing, nullView, point1)
Dim QC_IDSymbol As IDSymbol
QC_IDSymbol = idSymbolBuilder1.Commit()
'change IDSymbol layer to match that of the dimension or note it is attached to
QC_IDSymbol.Layer = 109
idSymbolBuilder1.Destroy()
noteNumber += 1
End While
lw.Close
theSession.SetUndoMarkName(markId1, "Label Dimensions")
theSession.SetUndoMarkVisibility(markId1, Nothing, Session.MarkVisibility.Visible)
End Sub 'Main
Function selectNoteDimension(ByVal prompt As String, ByRef obj As Annotation)
'Annotation class covers dimensions and notes
'Annotation -> Dimension
'Annotation -> DraftingAid -> SimpleDraftingAid -> NoteBase -> BaseNote -> Note
Dim ui As UI = GetUI()
Dim mask(1) As Selection.MaskTriple
With mask(0)
.Type = UFConstants.UF_dimension_type
.Subtype = 0
.SolidBodySubtype = 0
End With
With mask(1)
.Type = UFConstants.UF_drafting_entity_type
.Subtype = UFConstants.UF_draft_note_subtype
End With
Dim cursor As Point3d = Nothing
Dim resp As Selection.Response = _
ui.SelectionManager.SelectObject(prompt, prompt, _
Selection.SelectionScope.AnyInAssembly, _
Selection.SelectionAction.ClearAndEnableSpecific, _
False, False, mask, obj, cursor)
If resp = Selection.Response.ObjectSelected Or _
resp = Selection.Response.ObjectSelectedByName Then
Return Selection.Response.Ok
Else
Return Selection.Response.Cancel
End If
End Function 'selectNoteDimension
End Module Can anyone help me on this problem?
CSchnei
RE: nx journal to create Index number at dimension with adjusted orientation
CODE
'journal to Create Non- Associative Index Numbers at Dimensions or Notes Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Imports NXOpen.UI Imports NXOpen.Annotations Module Module18 Sub Main() '************************************************************************* 'change the following offset distances to get something that works for you 'offsets from dimension text Const XOffsetDim As Double = 0 Const YOffsetDim As Double = 2 'offsets from notes Const XOffsetNote As Double = -3 Const YOffsetNote As Double = 0 '************************************************************************* Dim theSession As Session = Session.GetSession() Dim workPart As Part = theSession.Parts.Work Dim displayPart As Part = theSession.Parts.Display Dim lw As ListingWindow = theSession.ListingWindow Dim noteDim As Annotation Dim noteDimOrigin As Point3d = Nothing Dim letterPref As LetteringPreferences = Nothing Dim symbolPref As SymbolPreferences = Nothing Dim dimpref As DimensionPreferences = Nothing Dim noteNumber As Integer Dim letterangle As Double Dim dimangle As Double Dim input As String Dim theAnnotationManager As NXOpen.Annotations.AnnotationManager = workPart.Annotations Dim idTextAngle As Double Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start") Do input = InputBox("Enter starting INDEX number: ", "Create Index Numbers at Dimensions or Notes", "") Loop Until (IsNumeric(input)) noteNumber = input lw.Open() While selectNoteDimension("Select Dimension or Note", noteDim) = Selection.Response.Ok If TypeOf (noteDim) Is Annotations.Note Then 'code for notes 'lw.WriteLine("note: " & noteDim.GetType.ToString) letterPref = noteDim.GetLetteringPreferences() letterangle = letterPref.Angle idTextAngle = letterangle Else 'code for dims 'lw.WriteLine("dim: " & noteDim.GetType.ToString) Dim theDim As Dimension = noteDim dimpref = theDim.GetDimensionPreferences() dimangle = dimpref.TextOrienationAngle idTextAngle = dimangle End If noteDimOrigin = noteDim.AnnotationOrigin 'lw.WriteLine("origin: " & noteDimOrigin.X & ", " & noteDimOrigin.Y) 'symbolPref = NXOpen.Preferences.AnnotationPreferences.GetSymbolPreferences() symbolPref = theAnnotationManager.Preferences.GetSymbolPreferences() 'lw.WriteLine("Alignment Position: " & letterPref.AlignmentPosition.ToString()) 'lw.WriteLine("ID Symbol size: " & symbolPref.IDSymbolSize) 'lw.WriteLine("Annotation type: " & noteDim.GetType().ToString()) Dim nullAnnotations_IdSymbol As Annotations.IdSymbol = Nothing Dim idSymbolBuilder1 As Annotations.IdSymbolBuilder idSymbolBuilder1 = workPart.Annotations.IdSymbols.CreateIdSymbolBuilder(nullAnnotations_IdSymbol) idSymbolBuilder1.Origin.Plane.PlaneMethod = Annotations.PlaneBuilder.PlaneMethodType.XyPlane idSymbolBuilder1.Type = Annotations.IdSymbolBuilder.SymbolTypes.Circle idSymbolBuilder1.UpperText = noteNumber 'use the symbol size set in the part idSymbolBuilder1.Size = 4 idSymbolBuilder1.Style.LetteringStyle.GeneralTextSize = 2.5 idSymbolBuilder1.Style.LetteringStyle.Angle = idTextAngle Dim assocOrigin1 As Annotations.Annotation.AssociativeOriginData Dim nullPoint As Point = Nothing Dim nullView As View = Nothing With assocOrigin1 .OriginType = Annotations.AssociativeOriginType.OffsetFromText .OffsetAnnotation = noteDim .OffsetAlignmentPosition = Annotations.AlignmentPosition.TopRight .AssociatedPoint = nullPoint .StackAlignmentPosition = Annotations.StackAlignmentPosition.Above .AlignedAnnotation = Nothing If noteDim.GetType().ToString() = "NXOpen.Annotations.Note" Then .XOffsetFactor = XOffsetNote .YOffsetFactor = YOffsetNote Else .XOffsetFactor = XOffsetDim .YOffsetFactor = YOffsetDim End If End With Dim point1 As Point3d = New Point3d(noteDimOrigin.X - 4, noteDimOrigin.Y + 6, 0.0) 'idSymbolBuilder1.Origin.SetInferRelativeToGeometry(True) 'idSymbolBuilder1.Origin.SetAssociativeOrigin(assocOrigin1) idSymbolBuilder1.Origin.Origin.SetValue(Nothing, nullView, point1) Dim QC_IDSymbol As IdSymbol QC_IDSymbol = idSymbolBuilder1.Commit() 'change IDSymbol layer to match that of the dimension or note it is attached to QC_IDSymbol.Layer = 109 idSymbolBuilder1.Destroy() noteNumber += 1 End While lw.Close() theSession.SetUndoMarkName(markId1, "Label Dimensions") theSession.SetUndoMarkVisibility(markId1, Nothing, Session.MarkVisibility.Visible) End Sub 'Main '************************************************** Function selectNoteDimension(ByVal prompt As String, ByRef obj As Annotation) 'Annotation class covers dimensions and notes 'Annotation -> Dimension 'Annotation -> DraftingAid -> SimpleDraftingAid -> NoteBase -> BaseNote -> Note Dim ui As UI = GetUI() Dim mask(1) As Selection.MaskTriple With mask(0) .Type = UFConstants.UF_dimension_type .Subtype = 0 .SolidBodySubtype = 0 End With With mask(1) .Type = UFConstants.UF_drafting_entity_type .Subtype = UFConstants.UF_draft_note_subtype .SolidBodySubtype = 0 End With Dim cursor As Point3d = Nothing Dim resp As Selection.Response = _ ui.SelectionManager.SelectObject(prompt, prompt, _ Selection.SelectionScope.AnyInAssembly, _ Selection.SelectionAction.ClearAndEnableSpecific, _ False, False, mask, obj, cursor) If resp = Selection.Response.ObjectSelected Or _ resp = Selection.Response.ObjectSelectedByName Then Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function 'selectNoteDimension '************************************************** End Modulewww.nxjournaling.com
cschnei
