Pressure vessel Design (wind and Seismic) as per Algerian Code/Regulations
Hello to all.
I need Some Guidance on Wind and Seismic Design of the Pressure vessels to be carried out using Algerian codes/Standards.
The vessels are generally designed with ASME Sec VIII.
If anybody is having some useful information /data / reference calculations please share it with me.
I am trying to search through internet, but all I get is mostly in French.
Thanks and Regards
Mrudul
RE: Pressure vessel Design (wind and Seismic) as per Algerian Code/Regulations
Some French men out in France should be able to help you out.
Applicable Algerian seismic and wind loads are widely listed on the internet, as follows:
Seismic Loads: RPA 99 / v 2003
Wind Loads: R.N.V.99 D.T.R. C 2-4.7
You can also download these standards from internet for free and use the appropriate values from the standards in the pressure vessel design software you are using.
Cheers,
gr2vessels
