Interpretation of Slab Design
I am to design a "200 thick slabs, 600 deep for the transfer, 200 thick core walls & 600x300 columns". Just checking if I am interpreting this correctly, does this mean I am designing a two way slab with 600 deep beams? Or a flat slab with 600 deep drop panels?
RE: Interpretation of Slab Design
1) 200 thick flat slabs at the typical, repeating levels.
2) 600 thick flat slab at a transfer level, likely a podium.
3) 600 x 300 columns.
Actually, I wouldn't assume anything; I'd ask the person who gave me the assignment.
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
The link attached shows the column arrangement plan, are you able to deduce whether it is a beam or flat slab?
Any response would be greatly appreciated.
