Calcite buildup in 8" pipes - anyone know if electronic scale treatment works?
We are looking at this type of unit (https://www.aquagenesisusa.com/commercial/industri...) for electronic treatment of effluent water from one of our processes.
The 8" piping gets about a 1/2" of hard calcite buildup within a week. Anyone have any comment on the electronic treatment or another recommendation?
We are also looking into water softeners and water PH neutralizers but those are expensive setup and yearly costs.
See attached pic of buildup.
RE: Calcite buildup in 8" pipes - anyone know if electronic scale treatment works?
Don't waste your money on one of these gadgets. They have been around for 80 years at least and have never worked.
What is the process that is creating the problem?
sludge drying. It is in an offgas cooling spray tower. We get high ammonia that raises the pH from 6ish to over 9 making things drop out and form the scale (what the lab people told me). We are looking at an acid injection in the water supply for at least a temporary solution and to get the pipes clean
Sulfuric acid will control the scale. Acid is also commonly used in cooling towers to lower the alkalinity.
You need to know what scale if forming, especially if it is more soluble at high temp, or more likely to form at high temp.
That way you can choose where in your system you prevent it from forming, and where you allow it to form and come out of your water (in a place that it does not cause damage).
Yes this will be an ongoing operations cost, but the gain in efficiency and reductions in maintenance will be significant.
Plymouth Tube
