what kind simulation or tool shouhld i use for this problem
i am working on the following project which is a scissor jack-lift design with a actuator driving the lift of the table.
may i know what kind of simulation or tool should i use, in order to find out the lenght of the actuator extented related to the height of the table. e.g: when table is at the height of 1600 , the lemght between the two leg is 1244.57mm
and i want it to show the lenght between the two leg when i enter certain heigh
RE: what kind simulation or tool shouhld i use for this problem
