DOC protection for over head line
I have a question about protection of high voltage (over 200kv) line.
Based on Siemens siprotec recommendation, high voltage line use two distance relay as sub1 and sub2 protection (main function). Also as common protection over voltage and DEF (directional earth fault) are used.
My question “DOC (directional over current) function is necessary for completion protection system or not?”
I know all famous brand distance relays including DEF and DOC. But I don’t know , if just DEF is enough why they were included DOC function.
On the other hand, we use two distance relay as main and backup. In this case, is there any need to additional function as DOC function for high voltage line?
Or is there any fault that may not clear by distance relays and need DOC function to clear it?
Another question is about 132kv line,
Also based on siprotec recommendation , they use under voltage as protection function,. But there is nothing about over voltage.
I think over voltage is also important for protection. And if this is not recommendation it means no fault leads to overvoltage.
Please give me some reference about that.
RE: DOC protection for over head line
DOC will just see foward.
If you don't want the distance protection to operate on a fault backward of the protection, you combine it with a DOC with a logical function "AND".
tem1234 :
Distance function have 4(or 5) zone that 3 of them are forward and one of them covers backward. It is not related to DOC function( Directional Over Current). My question is about necessity of DOC function when we use 2 different distance relay.
Distance protection is best solution "( ok, 87L too ).
Undervoltage protection for line is some exotic functionality. maybe used is undervoltage load shedding.
