How to create variable pitch helix spring in NX8.5
Hello.
I need a helix that satisfies the following criteria
total turns = 8
Radius = 80
total length = 560
pitch between start point and end of turn 5 = 40 / length = 200
pitch between start of trun 5 and end of turn 6.5 = variable pitch / length = 60
pitch between start of trun 6.5 and end of turn 8 = 200 / length = 300
I then need to sweep a section along this helix.
Any help would be greatly appreciated.
Best regards
total turns = 8
Radius = 80
total length = 560
Best regards
RE: How to create variable pitch helix spring in NX8.5
www.jcb.com
NX 8.5 with TC 8.3
www.jcb.com
NX 8.5 with TC 8.3
Just having a go at creating this model using a law curve, but I've got no idea how to get the "transition" section right.
Maybe someone else could have a go...
www.jcb.com
NX 8.5 with TC 8.3
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I haven't, I've made a mess of it.
You can see with the "original body", my new part using law curve doesn't really have a transition stage.
Pitch jumps straight to 200 from 40, and the result is a spring that's too long.
www.jcb.com
NX 8.5 with TC 8.3
www.jcb.com
NX 8.5 with TC 8.3
I've coloured my orginal model, in its 3 different sections.
You can see the pitch in my new model starts to increase before the spring has reached 200mm length.
www.jcb.com
NX 8.5 with TC 8.3
Also it appears that the Pitch by Law curve may have some problems. Instead I used points 'Linear along Spine' and I get the correct shape (see attached part file). As a check for my solution I've place some Datum Planes and intersection Points along the length of the helix to show the three 'pitch sections'. If you look you can verify the number of turns for each section. To see the final spring, just unsuppress the 'Tube' feature.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Best regards
And I think I've figured out the law curve.
In a simpler model, I found that changing length of a law curve did not affect the length of a helix.
So I guessed its x-dir must be related to "number of turns of a particular pitch".
So to test, I changed my helix to a "total length" helix, and created a law curve where lengths related to number of turns (I multiplied them all by 10 just to see if it really was a ratio).
And it worked!
No idea how to explain it better so here's the model.
www.jcb.com
NX 8.5 with TC 8.3
Can one of you explain the values used on the sketch which is used as law curve for the pitch?
What happens exactly when I change each value?
I'm trying to use this principle of creating a Spring which can be deformed in an assembly...
I'm having some problems on getting the overall length deformable while keeping the number of turns fixed.
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
Finally, I understand this!
Take my last model I posted, and change Helix (10) to be defined by number of turns, instead of total length, and there is no change in the helix.
So the "lengths" in the law curve are not lengths at all, they are the ratio of the total spring for which each "pitch" applies.
If I increase them all by 1.25 (so it reads out of 100% - attached), there is still no change.
www.jcb.com
NX 8.5 with TC 8.3
So if yours is a constant pitch spring (along its length), you just want to define your spring by number of turns, and alter the pitch value to make it deform. I think.
www.jcb.com
NX 8.5 with TC 8.3
www.jcb.com
NX 8.5 with TC 8.3
