NX UGDOC Search fix for Java 7 Update 65 and 67
I received the SFBmail yesterday, but can't find the fix ... is it available yet ?
NX 9.0.2.5 (Desperate for 9.0.3)
NX 10 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
RE: NX UGDOC Search fix for Java 7 Update 65 and 67
Do you really need it? I coudln't find the patch either, but as a test I uninstalled all the Java I had on my system and put on Java 7 Update 67 (32 and 64bit).
My NX8, NX8.5 and NX9 docs have been patched for Update 45, so no changes were made there.
Tested with Firefox 31 and IE 11 and search works as expected.
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.2, NX10 Beta
Anthony,
The Version 45 Patch also works for me but not others.
Why send out an SFBmail though, unless the fix is available,
NX 10 (Testing)
Quote (phillpd)
Can't answer that but it's not the first time I've seen SFBs refer to files that don't exist.
Anthony Galante
They're available now and I think they are needed (even though my system is fine).
I did an fresh install for a customer of NX8, NX8.5 and NX9, and used the older Java 7 Update 45 patch with Java 7 Update 67 installed.
The search in help would not work. As soon as I patched to the new patches referred to in the SFB, then it all started working.
Anthony Galante
Yes, I installed it yesterday, all is working well now
NX 10 (Testing)
