Weight display in Assembly Navigator
Hi Guys.
I have a strange situation where it will not display the weight of my part in the assembly navigator as it usually does. I have defined a material for the solids contained, saved etc, yet still no part weight.
Any ideas? I have 200 parts i have created within a large assembly i have created, yet just this 1 part file which will not show its weight, both in the containing assembly or when just the part is open.
Thanks in advance.
Thanks in advance.
RE: Weight display in Assembly Navigator
sorry new in NX
regards
Erwin
If it is a solid body, use the "examine geometry" command to make sure it is valid; it should pass all the body and face checks. Geometry errors can lead to weight calculation errors, drafting view errors, etc etc.
www.nxjournaling.com
File - properties - Weight tab.....
We sometimes find that the reference set being used is set to 'Entire Part' rather than 'Model', resulting in all solid bodies being included in the calculation. Other settings in this form will also affect the weight.
Mike Hyde
www.astonmartin.com
NX8.5 with TC9.1
