ZA27/29 replacement for cast leaded yellow brass (bronze)
I have a current application of a bronze hub w 2 ears in combination w a ubolt holding up a sign on a pole that has a galvanized steel threaded pipe going into the hub... Can I replace the hub w a less expensive all zinc piece? Will the cast leaded yellow brass or galvanized steel pipe have corrosion or rust issues with the zinc?
RE: ZA27/29 replacement for cast leaded yellow brass (bronze)
I'm just one step away from being rich, all I need now is money.
( read somewhere on the internet)
You are getting rid of the brass completely, right?
Fastening a galvanized pipe to a cast Zn part is no problem.
Though as has been pointed out, if you need more strength just use a galvanized cast iron part.
Then everything in the system will be galvanized and have similar corrosion resistance.
Plymouth Tube
Leaded brass does not have very good corrosion resistance.
A picture of the assembly with the parts labeled would help us to help you.
Plymouth Tube
Plymouth Tube
