Simple way to create spline normal to face? , NX7.5
I got the question on how to, fast & simple, create a spline which is normal to a face in both ends.
See attached example. The example is "exaggerated" to illustrate the question. In one end of the spline it should start at the end of the lines on top of the block, normal to the block, in the other end at the point, normal to the cylinder at the point.
I have not found a simple way of doing this in NX7.5, i.e without creating a number of helper lines to snap the tangent to. ( NX7.5 is our production release at the moment) Neither have i found a way of reversing a tangent if the tangent goes "the opposite".
Any ideas ?
- The simpler the better.
( And yes, the real model will look something similar, the splines represent wires. )
Tomas
Any ideas ?
Tomas
RE: Simple way to create spline normal to face? , NX7.5
If it is in the form of an embedded picture, it may be blocked by my company's firewall...
www.nxjournaling.com
Tomas
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I should point a few limitations. This journal only works for NX7.5 because the studio spline function is quite different for NX8 +. I have used a simpler approach in that the user is asked to make 4 selections. The start face, a point object on the start face and an end face and a point on the end face. It is possible to reduce this but makes the journal much longer. When I used the journal on the supplied example one of the splines was not identical as the existing spline. Not sure why this was so.
Anyway here is the journal. I hope it is of some help.
CODE --> VB
Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Module Spline2Points2Slopes Dim s As Session = Session.GetSession() Dim ui As UI = UI.GetUI() Dim ufs As UFSession = UFSession.GetUFSession() Dim workPart As Part = s.Parts.Work Sub Main() Dim point1 As Point = Nothing Dim face1 As Face = Nothing Dim point2 As Point = Nothing Dim face2 As Face = Nothing Dim message1 As String = "Select Start Face" Dim message2 As String = "Select Start Point on Start Face" Dim message3 As String = "Select End Face" Dim message4 As String = "Select End Point on End Face" Dim response1 As Selection.Response = Selection.Response.Cancel Dim response2 As Selection.Response = Selection.Response.Cancel Dim response3 As Selection.Response = Selection.Response.Cancel Dim response4 As Selection.Response = Selection.Response.Cancel start1: response1 = select_a_Face(message1, face1) If response1 = Selection.Response.Cancel Then GoTo end1 response2 = select_a_point(message2, point1) If response2 = Selection.Response.Cancel Then GoTo end1 response3 = select_a_Face(message3, face2) If response3 = Selection.Response.Cancel Then GoTo end1 response4 = select_a_point(message4, point2) If response4 = Selection.Response.Cancel Then GoTo end1 ' get the face normals Dim normal1 As Vector3d = New Vector3d getFaceNormal(point1, face1, normal1) Dim normal2 As Vector3d = New Vector3d getFaceNormal(point2, face2, normal2) ' create the spline CreateStudioSpline2Points2Slopes(point1, normal1, point2, normal2) GoTo start1 end1: End Sub Public Sub getFaceNormal(ByVal thepoint As Point, ByVal theface As Face, ByRef normal1 As Vector3d) Dim geometricProperties1 As GeometricAnalysis.GeometricProperties = Nothing geometricProperties1 = workPart.AnalysisManager.CreateGeometricPropertiesObject() Dim myFaceProps As GeometricAnalysis.GeometricProperties.Face = Nothing geometricProperties1.GetFaceProperties(theface, thepoint.Coordinates, myFaceProps) normal1 = myFaceProps.Normal End Sub Function select_a_point(ByVal prompt As String, ByRef selpointobj As Point) As Selection.Response Dim ui As UI = ui.GetUI() Dim selectionMask(0) As Selection.MaskTriple With selectionMask(0) .Type = UFConstants.UF_point_type .Subtype = 0 .SolidBodySubtype = 0 End With Dim cursor As Point3d = Nothing Dim resp As Selection.Response = _ ui.SelectionManager.SelectTaggedObject(prompt, prompt, _ Selection.SelectionScope.AnyInAssembly, _ Selection.SelectionAction.ClearAndEnableSpecific, _ False, False, selectionMask, selpointobj, cursor) If resp = Selection.Response.ObjectSelected Or _ resp = Selection.Response.ObjectSelectedByName Then Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function Function select_a_Face(ByVal message As String, ByRef obj As Face) As Selection.Response Dim selectionMask_array(0) As Selection.MaskTriple With selectionMask_array(0) .Type = UFConstants.UF_face_type .Subtype = 0 .SolidBodySubtype = 0 End With Dim cursor As Point3d = Nothing Dim resp As Selection.Response = _ ui.SelectionManager.SelectObject(message, message, _ Selection.SelectionScope.AnyInAssembly, _ Selection.SelectionAction.ClearAndEnableSpecific, _ False, False, selectionMask_array, obj, cursor) If resp = Selection.Response.ObjectSelected Or _ resp = Selection.Response.ObjectSelectedByName Then Return Selection.Response.Ok ElseIf resp = Selection.Response.Back Then Return Selection.Response.Back Else Return Selection.Response.Cancel End If End Function Public Sub CreateTempLineforTangents(ByRef pnt As Point, ByRef vec1 As Vector3d, ByVal dir1 As Integer, ByRef ln As Line) Dim linestartpnt As Point3d = New Point3d(pnt.Coordinates.X, pnt.Coordinates.Y, pnt.Coordinates.Z) Dim unitvector As Vector3d = MyUnitizeVector(vec1) Dim negatedvector = MyNegate(unitvector) Dim dist1 As Double = 50.0 Dim lineendpnt As Point3d = MyAffineComb(linestartpnt, dist1, negatedvector) Dim id1 As Session.UndoMarkId id1 = s.SetUndoMark(Session.MarkVisibility.Visible, "Lines1") If dir1 = 1 Then ln = workPart.Curves.CreateLine(lineendpnt, linestartpnt) Else ln = workPart.Curves.CreateLine(linestartpnt, lineendpnt) End If Dim nErrs1 As Integer nErrs1 = s.UpdateManager.DoUpdate(id1) End Sub Public Function MyNegate(ByVal v1 As Vector3d) As Vector3d Dim v2 As Vector3d v2.X = -v1.X v2.Y = -v1.Y v2.Z = -v1.Z Return v2 End Function Public Function MyUnitizeVector(ByVal v1 As Vector3d) As Vector3d Dim v2 As Vector3d Dim length As Double = Math.Sqrt(v1.X * v1.X + v1.Y * v1.Y + v1.Z * v1.Z) v2.X = v1.X / length v2.Y = v1.Y / length v2.Z = v1.Z / length Return v2 End Function Public Function MyAffineComb(ByVal p1 As Point3d, ByVal s As Double, ByVal v1 As Vector3d) As Point3d Dim p2 As Point3d p2.X = p1.X + s * v1.X p2.Y = p1.Y + s * v1.Y p2.Z = p1.Z + s * v1.Z Return p2 End Function Public Sub CreateStudioSpline2Points2Slopes(ByRef point1 As Point, ByRef normal1 As Vector3d, ByRef point2 As Point, _ ByRef normal2 As Vector3d) Dim line1 As Line = Nothing Dim line2 As Line = Nothing Dim dir1 As Integer = 1 CreateTempLineforTangents(point1, normal1, dir1, line1) dir1 = 2 CreateTempLineforTangents(point2, normal2, dir1, line2) Dim scalar1 As Scalar scalar1 = workPart.Scalars.CreateScalar(1.0, Scalar.DimensionalityType.None, SmartObject.UpdateOption.WithinModeling) Dim direction1 As Direction direction1 = workPart.Directions.CreateDirection(line1, scalar1, Direction.OnCurveOption.Tangent, Sense.Forward, SmartObject.UpdateOption.WithinModeling) Dim direction2 As Direction direction2 = workPart.Directions.CreateDirection(line2, scalar1, Direction.OnCurveOption.Tangent, Sense.Forward, SmartObject.UpdateOption.WithinModeling) Dim nullFeatures_StudioSpline As Features.StudioSpline = Nothing Dim studioSplineBuilder1 As Features.StudioSplineBuilder studioSplineBuilder1 = workPart.Features.CreateStudioSplineBuilder(nullFeatures_StudioSpline) studioSplineBuilder1.Associative = False studioSplineBuilder1.InputCurveOption = Features.StudioSplineBuilder.CurveOption.Retain studioSplineBuilder1.SplineMethod = Features.StudioSplineBuilder.Method.ThroughPoints studioSplineBuilder1.Degree = 3 studioSplineBuilder1.IsPeriodic = False studioSplineBuilder1.MatchKnots = Features.StudioSplineBuilder.MatchKnotsType.None Dim knots1(-1) As Double studioSplineBuilder1.SetKnots(knots1) Dim parameters1(-1) As Double studioSplineBuilder1.SetParameters(parameters1) Dim geometricConstraintData1 As Features.GeometricConstraintData geometricConstraintData1 = studioSplineBuilder1.ConstraintManager.CreateGeometricConstraintData() geometricConstraintData1.Point = point1 geometricConstraintData1.AutomaticConstraintDirection = Features.GeometricConstraintData.ParameterDirection.Iso geometricConstraintData1.AutomaticConstraintType = Features.GeometricConstraintData.AutoConstraintType.None geometricConstraintData1.TangentDirection = direction1 Dim nullScalar As Scalar = Nothing geometricConstraintData1.TangentMagnitude = nullScalar Dim nullOffset As Offset = Nothing geometricConstraintData1.Curvature = nullOffset geometricConstraintData1.CurvatureDerivative = nullOffset geometricConstraintData1.HasSymmetricModelingConstraint = False Dim geometricConstraintData2 As Features.GeometricConstraintData geometricConstraintData2 = studioSplineBuilder1.ConstraintManager.CreateGeometricConstraintData() geometricConstraintData2.Point = point2 geometricConstraintData2.AutomaticConstraintDirection = Features.GeometricConstraintData.ParameterDirection.Iso geometricConstraintData2.AutomaticConstraintType = Features.GeometricConstraintData.AutoConstraintType.None geometricConstraintData2.TangentDirection = direction2 geometricConstraintData2.TangentMagnitude = nullScalar geometricConstraintData2.Curvature = nullOffset geometricConstraintData2.CurvatureDerivative = nullOffset geometricConstraintData2.HasSymmetricModelingConstraint = False Dim constraints1(1) As Features.GeometricConstraintData constraints1(0) = geometricConstraintData1 constraints1(1) = geometricConstraintData2 studioSplineBuilder1.ConstraintManager.SetContents(constraints1) Dim feature1 As Features.Feature feature1 = studioSplineBuilder1.CommitFeature() studioSplineBuilder1.Destroy() ufs.Obj.DeleteObject(line1.Tag) ufs.Obj.DeleteObject(line2.Tag) End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image immediately after execution within NX GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately End Function End ModuleFrank Swinkels
