Vertical liquid seal for flares
There is a 30" gas line from venting witch goes into a liquid seal before the flare.
The recomendation that i heard is that the liquid seal must be an horizontal one. But I need to design it vertical. Anyone knows if it could produce waves or other problems? I need to avoid pulsating flow. Does anyone know witch internals can I introduce in it?
RE: Vertical liquid seal for flares
Have you worked in this devises before?
Thanks!
StoneCold
The client asked as about installing a liquid seal, i can´t move from that.
