Batch DXF export
Batch DXF export
Batch DXF export
Hello together,
I found the following journal:
http://www.nxjournaling.com/content/export-drawing...
But I could not get it running in NX 9.0.
I recorded the following journal. How could I modify it to batch export a complete folder with files?
CODE -->
' NX 9.0.1.3
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
'   Menu: Orient View->Front
workPart.ModelingViews.WorkView.Orient(View.Canned.Front, View.ScaleAdjustment.Current)
'   Menu: View->Operation->Fit
workPart.ModelingViews.WorkView.Fit()
'   Menu: File->Export->AutoCAD DXF/DWG...
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start")
Dim dxfdwgCreator1 As DxfdwgCreator
dxfdwgCreator1 = theSession.DexManager.CreateDxfdwgCreator()
dxfdwgCreator1.ExportData = DxfdwgCreator.ExportDataOption.Drawing
dxfdwgCreator1.AutoCADRevision = DxfdwgCreator.AutoCADRevisionOptions.R2004
dxfdwgCreator1.ViewEditMode = True
dxfdwgCreator1.FlattenAssembly = True
dxfdwgCreator1.SettingsFile = "C:\Program Files\Siemens\NX 9.0\DXFDWG\dxfdwg.def"
dxfdwgCreator1.OutputFile = "C:\Temp\Test_01.dxf"
dxfdwgCreator1.ExportData = DxfdwgCreator.ExportDataOption.Modeling
dxfdwgCreator1.ObjectTypes.Curves = True
dxfdwgCreator1.ObjectTypes.Annotations = True
dxfdwgCreator1.ObjectTypes.Structures = True
dxfdwgCreator1.FlattenAssembly = False
dxfdwgCreator1.InputFile = "C:\Temp\Test_01.prt"
theSession.SetUndoMarkName(markId1, "AutoCAD DXF/DWG Export Wizard  Dialog")
'   Dialog Begin AutoCAD DXF/DWG Export Wizard
Dim markId2 As Session.UndoMarkId
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "AutoCAD DXF/DWG Export Wizard ")
theSession.DeleteUndoMark(markId2, Nothing)
Dim markId3 As Session.UndoMarkId
markId3 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "AutoCAD DXF/DWG Export Wizard ")
dxfdwgCreator1.TextFontMappingFile = "C:\Users\User\AppData\Local\Temp\User16C4C08573fr.txt"
dxfdwgCreator1.WidthFactorMode = DxfdwgCreator.WidthfactorMethodOptions.AutomaticCalculation
dxfdwgCreator1.CrossHatchMappingFile = "C:\Users\User\AppData\Local\Temp\User16C4C08573fs.txt"
dxfdwgCreator1.LineFontMappingFile = "C:\Users\User\AppData\Local\Temp\User16C4C08573ft.txt"
dxfdwgCreator1.LayerMask = "1-256"
dxfdwgCreator1.ViewList = "Left"
Dim nXObject1 As NXObject
nXObject1 = dxfdwgCreator1.Commit()
theSession.DeleteUndoMark(markId3, Nothing)
theSession.SetUndoMarkName(markId1, "AutoCAD DXF/DWG Export Wizard ")
dxfdwgCreator1.Destroy()
End Sub
End Module
Thank you very much
Goof
Siemens NX 8.5 / 9.0
