Riveting Titanium flat sheets to steel, Best to use Titanium or steel rivets to avoid corrosion?
Would riveted Titanium panels make chrome plated steel any more prone to corrode?
Which is better to use steel, stainless steel or Titanium rivets to avoid the chrome plated steel frame corroding?
RE: Riveting Titanium flat sheets to steel, Best to use Titanium or steel rivets to avoid corrosion?
If conditions are dry, it won't matter. But in wet locations, where the two metals are continuously bridged by an electrolyte, yes the titanium/steel galvanic couple will cause the chrome plated steel to rust more quickly than if the titanium weren't there. So the corrosion in a wet location is inevitable. If the concern is corrosion leading to failure of the rivets themselves, then I presume you'd be better off with titanium rivets. But if the concern is corrosion of the steel base metal, you're no better off either way as far as I can see.
But the platting isn't perfect, and the Ti will only aggravate the issue.
As MM said, if you use Ti rivets then at least the rivets won't be the first thing to fail.
But the steel will rust if there is moisture.
Plymouth Tube
