Drag selection window not showing?
So after updating draftsight today, my drag to select window is not working. When I click and hold and pull the cursor across the drawing area, nothing happens... In the command line it says "._MAINSELECT" Any ideas? In the help file i can only locate info on how to operate the selection window, but nothing about turning it off or on.
Thank you for your time!
