Material selection
Material selection
Looking to make a small gas combustion camber to burn NG. I was looking at stainless 304. Just wondering on thickness of the wall should be or would it be best to line it with ceramic? Is there another metal that is best to be used in a fire tube? Is there a thickness chart vs. BTU you want or something in that nature?
RE: Material selection
However first we need the expected temperature of your combustion chamber.
B.E.
You are judged not by what you know, but by what you can do.
